dougrainer
Jun 15, 2019Nomad
mikestock wrote:
I do have the updated jacks. I plan to go to Red Bay on Monday. I feel confident that if Brent says the new controller will work, Tiffin will stand behind it.
Yes, you have the updated jacks, But are the Sensor wires at each jack connected to the wire harness? If not, then the new control board and touch pad will not work. Your Motorhome HAD to have the updated wire harness installed also. Brent did NOT state it would work if you did not give him the correct info. He stated it would work as long as all 4 jacks have the 4 wire connections AND the Wire Harness has been replaced with the updated harness. Doug
38,769 PostsLatest Activity: Apr 03, 2026
