cbr46
Nov 13, 2019Explorer
Atwood Furnace Problems
I posted this in an existing post a few days ago in Tech Issues forum. No one is responding so (forgive me) I'm also posting here.
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/29966083.cfm
My Atwood SF-35 furnace is 17 yrs old. Some surface rust but overall pretty clean.
Fan comes on, a minute or so later gas is turned on and I can hear the igniter frantically clicking (as it should).
I faintly smell propane coming out the furnace exhaust. FAINTLY. I'm not sure how strong of a smell it should be. The smell comes & goes.
Sometimes the furnace will light but then goes out. I can hear a 'woof' or two . . . or multiples.
Sometimes it will run for a few minutes but never reaches a good outlet temp. Maybe 90F. Normal is 120F+.
Other gas appliances work as they should. Batt voltage is 12V+
There were muddobber nests inside the flame chamber. They were cleaned out. Otherwise the inside was pretty clean.
The burner was removed and although it looked clean I ran a quick brass wire brush on it (by hand). I also inserted a rubber coated electrical wire into the gas jet. It went in easily letting me think the jet wasn't clogged. I didn't remove the jet to look for rust inside the tube. The igniter tip was cleaned and is 1/8" from burner (spec).
So where from here?
#1 I don't want to spend $90 for a control board I may not need. Yes, I'll get a Dinosaur board if I replace.
#2 The furnace isn't easy to disassemble - the supply tube nut is so tight I have to completely disassemble the fan shroud to get the tube out. Laborious!
Any experience with gas valves quitting . . . . or rust inside the supply tube (clogging the gas jet)?
Can I apply 12V to the gas valve to actuate it? For testing ONLY!
It's cold out! Fortunately I don't have a trip planned for a week or two.
Thanks,
- bob
So where from here?
Thanks,
- bob
