Artum_Snowbird
Jun 06, 2017Explorer
Many a leak can start from the pressure release valve too. It's only a ten dollar fix and might be worth it for an easy fix. It could leak all the way down to the inlet inside the insulation.
Is it an electric/gas model?
Put a paper towel around the fitting where you suspect it is coming from, and put the pressure to it for just a short time. You will notice the wetness on the towel before you will see the drips if it is coming from there.
38,766 PostsLatest Activity: Jan 10, 2026
