rk911
Dec 04, 2018Explorer
check the thermal cutoff for continuity. the brown wire from the t-stat plugs into one end of the thermal cutoff and the other end plugs into the t-stat connection. if you don't have a meter remove the thermal cutoff and plug the brown wire directly into the t-stat connector and see if the WH works on elec.
38,766 PostsLatest Activity: Jan 10, 2026
