Old-Biscuit
Dec 04, 2018Explorer III
3E version.....
Electric is completely separate system
ALL electrical is on backside
120V AC T-stat/ECO, element and OEM on/off switch
NOTE: The ECO (Energy Cut Off---High temp t-stat) if tripped should be a manual reset button in center of ECO.
Only thing you can check/test is IF the AC circuit Breaker is tripped and if reset it passes AC Voltage
Every component in the outside compartment is 12V DC for the propane system. Nothing for the 120V AC electric.
38,766 PostsLatest Activity: Jan 10, 2026
