Old-Biscuit
Dec 04, 2018Explorer III
rk911 wrote:
check the thermal cutoff for continuity. the brown wire from the t-stat plugs into one end of the thermal cutoff and the other end plugs into the t-stat connection. if you don't have a meter remove the thermal cutoff and plug the brown wire directly into the t-stat connector and see if the WH works on elec.
Propane would NOT function if thermal fuse was blown
OPs version the electric doesn't use the thermal fuse or any component in outside compartment.
38,766 PostsLatest Activity: Jan 10, 2026
