Dale2000
Oct 02, 2019Explorer
Atwood Jacks/Levellers issue
I've got the typical issue with Atwood levellers, where I have a red&green light flashing at one specific leveller (rear-passenger side). Thankfully, the internet/web is full of things to check, and even has the manual to go through, with a Troubleshooting portion. I've tried disconnecting the offending jack...which by the way, is the newest jack (has the 4 wires) and still has the tags on it from new, reconnected and did what the manual said to do to rid myself of the error issue, with no positive results.
My question is, if it could be the Controller or the Keypad? I have set up an appointment at an RV service centre, but thought I would try and figure this out on my own if possible, as the appointment isn't for another 2 weeks.
I know some have switched out to an HWH or other system, but up to this point my levellers have been working just fine. All levellers are at the top, and I can get the drivers side to go up and down, but the levellers on the passenger side do nothing when trying to manually lower them. Nothing happens when I choose the 'Auto'...where they use to all go down just fine in this manner. The connector on the offending jack looks just fine, but I haven't checked to see if 12V is going to it. I thought I'd ask if anyone has any other ideas as to what the possible issue might be (open to all opinions/suggestions). I get no other LED lights that shouldn't be on, other than the two offending 'red/green' blinking and the audible beeping.
Seems to be a full 12V and no 'wait' lights on. With the levellers not working correctly, it affects the air bags as well. To move the coach, I disconnected the keypad to stop the audible beeping...but that as well affects the air bags (put the E-brake on and N and the air bags deflate, and every time I put my foot on the brake when driving, the levellers ratchet!
