- bennefimExplorerControl board mounts on dash. Part number is 26673.
Doug - dnrnhrdExplorerWhich board do you have- the one that mounts inside and has the buttons- p/n 66555 or the board that mounts 'under' the rv? I am interested in the board that mounts under the rv. thanx.
- bennefimExplorerWe had Equalizer auto jacks installed at Elkhart factory and have been very pleased. Only spare part left is the control board if anyone interested.
Doug - ScottiemomNomad IIWe went to Tiffin in June looking for jack replacements and a control board. Only found used jacks over at bunkhouse. Control board could be found on line. But you could spend a couple thousand for these used parts and have the same problem next time you went to use them. So we bit the bullet and put on a complete new BigFoot system. Yes, it was expensive, but we live fulltime in it and needed to have a working jack system. They have been great.
Dale - bennefimExplorerThanks Doug for the tip. Called Tiffin and they are all gone. They had replacements made for their Tiffin customers.Very good company! They mow use Hwh.
bennefim wrote:
The problem I have always had the Jack's overextend,Shear a pin/gear then want retract or extend, Just loose. No replacement Jack's or parts anymore.
Contac Tiffin motorhomes in Red Bay. They did have complete jacks still available a few months ago. Doug- bennefimExplorerThe problem I have always had the Jack's overextend,Shear a pin/gear then want retract or extend, Just loose. No replacement Jack's or parts anymore.
- deprivedExplorerMay I ask what problem you are having?
- bennefimExplorerGot prices for hwh, bigfoot and equalizer. High to low was hwh, Bigfoot, then equalizer.
- Bruce_BrownModeratorI've been looking at Equalizer. We all know HWH is good but wow they're pricey.
Sometime in the near future we too need to make a decision.
38,783 PostsLatest Activity: Sep 23, 2026
