FreshAir
Jul 17, 2013Explorer
Lobstah wrote:
My 05 Pace has it mounted under the dash on the driver's side, tight up into the corner with the front edge of the module screwed into the firewall, and the left edge of the module screwed into the left side of the coach. Mine is mounted as high as possible in that space, so looking at it from the bottom, you might not even recognize it.
My control panel is on the left side of the dash from the steering column. If you take the screws out that hold your button/control panel to the dash, you can trace the wire from the panel to the control module.
Jim
Thank's Jim. That's where it is. I have a fuse block setting in front of it. Not sure I would have found it if not for your exact instructions.
Pat
