Thunder_Mountai
Oct 17, 2014Explorer II
Dakota98 wrote:
Sounds as though you have a single valve bypass setup. If that's the case then the check valve in the top of the tank, outlet is not functioning correctly and needs to be replaced.
If there is not a check valve in the outlet of the tank, you'll have to install one or use air to winterize, or you'll have to fill the tank with pink stuff. Just be sure the inlet valve is open to the tank if you decide to use air.
I agree. I have a single gate valve for the heater bypass and a check valve. Last spring when I returned from AZ, I couldn't get pressure built up in the fresh water system to winterize the washer. Then I noticed pink stuff dribbling out of the water heater drain. Turned out that the check valve was leaking back into the water heater.
The part was less than $25 retail. It took about 45 minutes to pull the heater, thirty minutes to replace the check valve and 45 minutes to reinstall.
A temporary fix would be to disconnect the cold water line from the heater and cap it until you can fix it.
38,705 PostsLatest Activity: Jan 14, 2025
