dougrainer
Mar 06, 2017Nomad
1. If left on during your trip, it kept the water HOT.
2. So, when you returned home and checked, if the water was already hot and not needing to be heated NOTHING will happen from both switches until the tstat calls for heat.
3. Go to the POP OFF valve of the water heater. Pop it open and see if you have HOT Water.
4. Also, if your unit has Motoraide, then the chassis engine heated the water in transit. Doug
38,782 PostsLatest Activity: Sep 10, 2026
