- Old-BiscuitExplorer III
Chris Bryant wrote:
On the DSI (electronic ignition) models, it is preset at 140 degrees. There is a retrofit adjustable thermostat, Atwood p/n 93105.
True^^^^^^
Also have an optional pre-set 130*F t-stat Atwood 91470
Unless your 6 gallon is an XT model
Those use a pre-set 160*F t-stat and a 'Mixing Valve' set for 130*F out.
Mixing valve 'can be' adjusted but are pre-set and 'sealed' so one has to 'unlock' them to be able to adjust them. - Chris_BryantExplorer IIOn the DSI (electronic ignition) models, it is preset at 140 degrees. There is a retrofit adjustable thermostat, Atwood p/n 93105.
38,759 PostsLatest Activity: Nov 09, 2025
