dougrainer
Apr 16, 2016Nomad
IF you have the 1986 Pace Arrow, then NO the charging from the genset is NOT the same as the engine Alternator. 1986 means you probably have a POWER CONVERTER(not an Inverter/Charger). A Power Converter does charge the coach batteries but is basically a trickle charger on your year model. The Chassis engine Alternator is a higher amp/voltage charger and will charge faster than on Genset. The Genset HAS NO charger. It powers the Converter, which then charges the coach batteries. As to your quest for an audible indicator. I have never heard or seen one in 37 years as a tech. There is a poster on these forums called mexicowanderer and he has a lot of expertise in aftermarket appliances for electrical items. Maybe he will be able to point you to something you can use. Doug
