B_B_UpchExplorerJul 01, 2016auto park woesOk so I have a 96 tiffan & the autopark light is on & the buzzer is sounding. It doesn't matter if it's in park or any other gear or if the key is on or just in the run position. I have checked the f...Show More
fyrflieExplorer IIIJul 01, 2016Search irv2.comYou will find a plethora of documents to use.Also look for a guy named Old Used Bear.He is the auto park guru.Did you check the pressure switch at the actuator?Mine is gray in color and has failed just like the rotten green switch.I now carry spares of both so that I can repair in the field if needed.AmazonAlso check out http://www.oemys-performance.com/You will find all of the part numbers there.
