Ok so I have a 96 tiffan & the autopark light is on & the buzzer is sounding. It doesn't matter if it's in park or any other gear or if the key is on or just in the run position. I have checked the f...
B. B., I believe it is most likely your actuator leaking. If you are handy, you can take it off and have a hydrolic shop rebuild it. I had to do that once. I had it off, rebuilt at a shop and reinstalled all in less than a day. Good luck,
