rekoj71's avatar
rekoj71
Automatic Retracting Steps help
The automatic steps on my RV extended today when I started the MH. It's a 2013 Fleetwood Bounder Classic, that I've had for 2 years now and even drove just 2 weeks ago for 800miles with no problems, and I haven't done anything that I can think of that would have changed how they should behave. If I turn off the engine the steps extend and retract with the door opening and closing like they should so I think the magnetic switch is working, and if I turn the switch for the steps they will stay extended like they are supposed to no mater the door position as long as the key is out. So why when I now, this week try to drive it I can turn off the steps switch so the steps retract when I shut the door, but I turn the key on and the steps extended. I won't be near the RV till tomorrow but looking for some ideas to look for when I get to it tomorrow.
I got them to retract by closing the door with the key out and then disconnected the Power junction (4 wires I think), and that kept them up to drive, but I had to leap into the MH to get to where I needed to go.
I'm good with a multi-meter but not sure where to start looking or what color wire does what. Sorry I don't know the brand and didn't see a label but I was in a hurry.
Thanks in advance,
Brian
  • I had a similar thing with my 07 Journey. In the wiring goi g to the step, there was a short "extension cord" connected to the plug coming from the chassis and then to the plug goi g to the steps. In the short extension there was a wire coming out going to ground. It turns out that extension has a diode in it protecting the the step circuit board from an over voltage. The diode had shorted the wire to ground. I removed the etension and plugged the step connector directly into the chassis connector, and the step worked perfectly. This was an easy workaround until I replaced the diode.
    Don't know if that helps you......good luck.
    Jeff
  • I am at a location with limited and throttled interconnect so can't say much. Read the trouble shooting steps in your manual. If they are Kwikee, you'll find the help you need.
    Good Luck
  • I don't know if they are the same steps, but I just got a recall notice on my 2015 Itasca about the steps extending while the engine is running. You might check with Fleetwood.
