bsinmich wrote:
You don't state the brand of steps but if they are Kwikee there is no manual use of them.  They do not have enough oomph to hold them in either position without the motor.  When you put any weight on them they will slide all over the place.  The motor is usually from a Ford power window.  Mine is 3 steps and is from a '79 Lincoln LF.  Others have found Taurus motors work.  Be very careful when working on them.  They have enough torque to break or remove fingers or anything else in their way.
I think Kwikee moved away from window motors several years ago.  My 2006 steps use a DC motor available from AM equipment.  You can order directly from them at a lower cost then Kwikee.
