bpope212 wrote:
The step from the top automatic step onto the first step into the unit is very steep.
I believe from the quote the problem is the distance from the top automatic step to the bottom fixed rv step which is also the door threshold, like this:
If this is the case adding more steps below the threshold at the top of the auto step won't help. Changing this distance would require cutting and remounting the auto steps under the door.
Instead you might consider turning off the auto steps and using a box like pictured below, built to your specs.
