udidwht
May 04, 2018Explorer
Auxiliary Fan?
I have a 1994 Fleetwood Southwind Storm 28ft with a 454 TBI (4L80E) and I'd like to confirm the fan (1) that is mounted on the front of the A/C condenser is working or or not. I don't recall ever seei...
77rollalong wrote:udidwht wrote:
I have a 1994 Fleetwood Southwind Storm 28ft with a 454 TBI (4L80E) and I'd like to confirm the fan (1) that is mounted on the front of the A/C condenser is working or or not. I don't recall ever seeing it on.
I've heard conflicting ideas of when it actually comes on such as...
Will come on when A/C and engine temp is roughly 220 or so.
Will come on anytime the A/C is on regardless of engine temp. (Haven't seen this myself).
So which is it? And what would be the easiest method of ensuring the fan is working correctly. I know it's tied into the PCM and the passenger side sensor (cylinder head) and possibly the A/C pressure switch.
Picture of my fan...
https://www.dropbox.com/s/oilh4kcssl2dkcn/IMG_0411%5B1%5D.JPG?dl=0
1994 Fleetwood Southwind Storm Chevy P-30 28ft 4L80E 454TBI
VIN#1GBJP37N4R3314754
56,139 US miles
you are correct, it should come on when the AC is turned on independent of the engine temp, you may have a 2 speed fan as well, check the fuse box under the hood, and see if there is 2 coolant fan relays in the box, i had a test relay that had a switch so i could just remove a relay, and plug in a test relay and turn on and off what ever i need to , there should be a fan Fuse also in the same fuse box...
