- Mile_HighExplorerOn our carefree on our fifthwheel, if the awning slid down the tube just a bit (wind), it would roll up with the arms not truly square and they would stick when trying to unroll to the point I had to tug on the arm. I just wrestled that awning and tube to realign it. It only took a fraction of an inch.
- crassterExplorer IITypically they just extend out. What is it getting stuck on? Is there any parts that need some wd-40?
- Yes, I have had that happen. I fixed it. Doug
- Winnebago_BobExplorerDoes it have pneumatic helper arms (gas shocks)? If so, that could be it.
- PastorCharlieExplorerThe motor end bushing is exposed to the weather and sometimes it will rust from inaction....Need to be lubed with Blaster if that is the case.
- CA_TravelerExplorer III
outboardfever wrote:
Mine was similar and the issue was the Monaco and CareLess wiring. Of course there can be other issues.
Has anyone had a electric awning that will not extend? Mine will unroll but not extend unless you pull on the arm.
What model awning, rig, etc? - wrgrs50sExplorerJust a thought but is your battery fully charged?
Next maybe your arms are binding up. Try some silicone lubricant and see if it helps.
Motor just may be going bad !!! Expensive ! - 2oldmanExplorer III think gravity does the extending. Is your coach upside down?
38,769 PostsLatest Activity: Apr 03, 2026
