dadd45
Jul 21, 2013Explorer
Wrong Lane wrote:
Don't know about other awnings but on mine there is no need to drill an end cap to replace the strap. It slides in the same groove that allows us to hang straps for awning lights, hanging flower pots, screen rooms etc. The groove the strap is in is open at the end of the roller closest to the rear of the motorhome.
I have done this alone before.
Put your awning control lever/handle in the "down" position. Grab a picnic table and pull it up beside your rig. Grab the awning in the middle and start pulling out and down. The mechinism in the awning should hold it from closing just as it does when you use the strap.
Eventually you will see what's left of the broken end of the strap, grab it and continue to deploy the awning until it is fully extended. The awning strap is attached to a plastic "T" in a groove. Slide it towards the rear of the rig and you should see that the groove lines up with a pre-cut slot in the end cap of the roller. Remove old strap, insert new pull down.
This has happened to me when I was in the boonies with no replacement strap and nowhere to buy one for 100 miles. If stuck, you can tie some rope around the broken strap leaving enough rope exposed so when the awning is rolled up a piece of rope can be seen. Tie a loop in the end of the exposed rope and you can then use your awning as per normal until you can secure a new pull down.
X2
38,769 PostsLatest Activity: Mar 28, 2026
