Hello, I just bought an 83 Pace Arrow. It was towed here and the axle shafts were pulled out of it. I went to put them back in. The first one went in without any issue, a bit of wiggling back and ...
NewbRVer.....First, you need to take a break from it for a few minutes so it doesn't make you crazy. You need to get both rear wheels off of the ground. Have someone turn the other side while you try to insert the one that doesn't want to go. Use vicegrips as suggested or something to give you some leverage to tilt the gear end up as you try to insert it.
