NewbRVerExplorerJun 07, 2015Axle shaftsHello, I just bought an 83 Pace Arrow. It was towed here and the axle shafts were pulled out of it. I went to put them back in. The first one went in without any issue, a bit of wiggling back and ...Show More
NewbRVerExplorerJun 07, 2015I should add... its to the point that the back of the gears are touching the plate, it's just that last mesh that I can't hit.I point this out because with it still about 6 inches out, you have to get the end (inside) up a bit to get it to go further and that was no problem. It's just getting the teeth to slide into their spots that isn't happening.
Related ContentEaton 17,000# axle shaftReplacement WDH shaftDrive shaft disconnectDrive shaft lock outDrive Shaft Disconnect
