I just bought a Trail Lite B+ 211s with 8.1 Chevy engine. This is my fifth motorhome (others range from an old 20' Vagabond, and three Winnegagos, from 19 to 32'. This vehicle is fantastic. I am...
Good points. You've just solved my other dilemma about AC power source. As you suggested, disconnecting the Parallax charging wire and just using the add-on charger (my spare trolling motor charger) plugged into the coach AC wiring. I have an AC outlet beside the sofa (wired under the stove which is just aft of the sofa). This way I can just use the existing shore power cable and not run a separate extension to the TV just for charging. It helps to discuss this stuff! Thanks.
