We've used our FW tank for all our water needs for 8 yrs, and only just come up w/ a clarity prob in one batch.
We emptied tank running the water pump. Then, I found a little T-handle drain that you unscrew w/ several turns and releases a thin stream of H2O to the outside - it is a black hose screwed into the tank side (near to) the bottom of the tank.
Is this thin stream proper to you guys?
Wouldn't there still be some very bottom dirty water left below the lower edge of the side black hose opening?
If so, how do I easily get all water to drain?
