A picture of the input/output jacks of the TV might be googled, as well as one for the dvd/surround unit. If TV is older, it (and/or the digital converter box) might only have stereo output sound RCA jacks for L and R channels. Hooking these to L and R input jacks of DVD unit would be what is needed. No 5 channel surround, though.
If you can’t see an easy way to access the back of the set with a hand, and using the picture to know by feel where to plug in the L and R RCA wires, you might have to look for how to remove screws to what is likely a wood frame that keeps TV contained in place (how mine was). Your main problem as I figure is access to see where to connect. The connections are simple household electronics plug in wires to jacks. If you go to RV place, $100/hr, but likely a ½ hr job. Maybe a car audio installer…or a responsible techie teenager.
