Daniel_C_
Feb 25, 2002Explorer
B+ motorhomes
I just bought a Trail Lite B+ 211s with 8.1 Chevy engine. This is my fifth motorhome (others range from an old 20' Vagabond, and three Winnegagos, from 19 to 32'. This vehicle is fantastic. I am...
mstanis wrote:That is a low mileage unit. We are close to 50k miles. Our floorplan is slightly different, so not sure how easy it would be to get to your water pump. Ours is under the dinette and can be seen by taking off the cushions and lifting up the thin plywood cover. Our water pump sits on rubber bushings and is bolted down to the wood floor underneath. If yours is not mounted, you likely have holes in your wood floor allowing rainwater to be splashed up onto your floor. Our pump looks a lot like this one - Camping World water pump
Gene
Yes it is that model. My understanding is that unit was in one family, grandpa->father->son. It had a little under 22K miles when I bought it last May.
Orion_42 & cheeze1
Thanks for the valuable info. I have been working at a Habitat Cara-A-Vanners build here in FL this week. Next week will be vacation time, and I hope to look at some of the areas mentioned. I'm thinking it is the water pump. It is no longer mounted to the floor, it appears the mounting hardware broke. I have a plastic container under the pump. I did drive through a lot of rain last weekend however, which made me wonder.
