Daniel_C_
Feb 25, 2002Explorer
B+ motorhomes
I just bought a Trail Lite B+ 211s with 8.1 Chevy engine. This is my fifth motorhome (others range from an old 20' Vagabond, and three Winnegagos, from 19 to 32'. This vehicle is fantastic. I am...
Teacher's Pet wrote:Teachers Pet - Well after reading more about your battery situation, I guess it has not been so terrible after all. And the Chevy chassis we both have should be comparable.Gene in NE wrote:Teacher's Pet wrote:What chassis is your Model 213 sitting on? The reason I ask is our Chevy 211-S sits in a metal shed when not used from about late September to middle May and so far has not been a problem. Fires right up. Chassis battery is new in November 2010 and house battery on October 2004. However, the house battery had to be replaced this year. The generator does not get much use, but it is run until the carb is dry.
Got the B+ out of heated storage after two years about two weeks ago. New battery, new generator carb, antifreeze and temp sender all needed. Plan on a 2-3 day trip before putting back in storage for winter. No use last summer due to both of us having surgeries. Will move to new storage facility, this fall closer to where we summer, with in and out privileges.
I had a fuel shut off installed for the generator so I can run the carb dry and fog the intake like we did our boats for 25 years. Seafoam did not keep the carb from gumming up while in storage.
2004 Chevrolet series 3500 Express Chassis. Chassis battery was new in April 2012 when purchased, since original had to be jumped at seller's location. Have 2 AGM house batteries installed May 2014. 1st set installed in April 2013 before an Alaska trip. Those AGM batteries were destroyed over the next winter by me leaving an 800 watt inverter on, completely draining the batteries and causing them to bulge, would not accept a charge at all. Our generator has 55 hours on the meter, runs great now, hope it does next spring.
