Daniel_C_
Feb 25, 2002Explorer
B+ motorhomes
I just bought a Trail Lite B+ 211s with 8.1 Chevy engine. This is my fifth motorhome (others range from an old 20' Vagabond, and three Winnegagos, from 19 to 32'. This vehicle is fantastic. I am...
bobndot wrote:
Hi Dale, this is probably a common blocked canister where the vent hose becomes clogged as well. It should be a simple fix by your mechanic.
Its EPA ORVR - 'Onboard Refueling Vapor Recovery' related , as you pump gasoline into your gas tank it pushes out air thru a vent tube canister filter setup. When the air can't escape due to a clogged line then the nozzle at the fuel pump shuts off.
Those nozzles are highly intelligent, I don't how they know when those canisters are clogged but they do. :)
