Just got back Yesterday evening. I am convinced that I should have a bigger unit if I ever full time again, but was able to flourish well for a week with the dogs and one traveling companion. I did develop a problem with the slide, noticing that the bottom has pulled apart from the side. I had noticed that the floor brace (with the roller attached)pulled up at the end of securing the slide, so that the roller is about half an inch in the air. It appears that when it does that the fiberglass side is supporting the entire weight of the couch when the slide is in. The weight of my dogs on the couch was enough to pull the bottom away from the side of the slide! I am leaving the slide secured while I decide when I can get the unit in for repairs. Other than that, I have been able to drive the motorhome like a car for the entire trip, cruising at 75 mph at times (and making excellent time). I got about 10 mpg for the entire trip.
