todd k:
Before you ship your unit overseas, please pay attention to the problem I am currently having with the slide on my unit. I discovered (after seeing the side break away from the bottom support) that the side supports the entire weight of the couch if the rollers on the bottom of the couch lift up when the slide is secured in the driving position. I wondered about the alignment when I first got the unit early in the year, and on my recent trip of 3000 miles, the separation occurred. It doesn't seem like a major fix, but aligning the slide so it doesn't happen again might be! I echo your delight with the handling of the B+. The main advantage of the Trail Lite is weight saving, though some shoring up of appliances and drawers might be in order for rougher roads, which will add some weight. I have the chevy chassis and frequently forget that I am not driving a regular van.
