I just bought a Trail Lite B+ 211s with 8.1 Chevy engine. This is my fifth motorhome (others range from an old 20' Vagabond, and three Winnegagos, from 19 to 32'. This vehicle is fantastic. I am...
Dan, Thanks for the info. I’ll check the slide. A solution might be to weld a flat steel piece above the caster that would act as a track and prevent the caster from rising. You’re right about a little reinforcement of the drawers, too. I think that it can be done by putting small blocks in the corners. Todd
