I just bought a Trail Lite B+ 211s with 8.1 Chevy engine. This is my fifth motorhome (others range from an old 20' Vagabond, and three Winnegagos, from 19 to 32'. This vehicle is fantastic. I am...
Tony, The TV is operated on 110Volts unless you have purchased an inverter (12v to 110v). The main 110 volt panel located under the sink, brown in color, is control to the 110 Volt TV, and also the 110 Volt converter which changes 110v to 12volts, has that been tripped??? If so, you will not get any battery charging. The use - store control by the doorway is only for 12 volts.
