I just bought a Trail Lite B+ 211s with 8.1 Chevy engine. This is my fifth motorhome (others range from an old 20' Vagabond, and three Winnegagos, from 19 to 32'. This vehicle is fantastic. I am...
Be careful and do some research. Most "expanding foam" sold in home supply stores uses formaldehyde and releases that as a gas. It is usually used for outside work. Of course, most of our toilet products use something much the same, but that is vented to the outside. Is it possible to insert toggle bolts from the sides? The expanding action of the toggle might add support to the top and bottom of the cabinet surface.
