To Trail-lite B+ owners, you might want to check the location of the frig drain hose in the outside frig compartment. My installation manual calls for the drain hose to be installed so it exits down thru the bottom of the coach. Instead, my hose was attached with a plastic clip to the wood base of the outside frig compartment, leaving any water to drain onto the wood. My dealer now has the hose hanging out of the outside louvered panel. A sloppy fix, in my opinion, for something that should have been done right to begin with.
