wragans - Good suggestions on the curtains. I also thought about the possibility of borrowing one of the tires from the rear to replace one on the front if need be. However, I remember years ago when driving a loaded straight truck that when one of the rear tires was either low or had a blow out, the second was only a few miles or feet before it blew also. I am afraid that I do not check the air pressure in the rear duals.
My flimsy dinette table did some rattling, found it was the adjustment in the leg support. Removed the adjustment and replaced with a bolt and the rattle went away.
Gene
211-S Chevy
