I just bought a Trail Lite B+ 211s with 8.1 Chevy engine. This is my fifth motorhome (others range from an old 20' Vagabond, and three Winnegagos, from 19 to 32'. This vehicle is fantastic. I am...
thank you...I read them, as well as about everything else...seems like our problem is unique (or at least I did not see the same one). Ours leaks when it is closed, not open. If we keep it open, it stays dry. After several 'fixes' it looks like the water comes in somehwere and sits on the outer top edge(both sides) of the slide...then works it's way down the sides. They have replaced the seals/added a top drain moulding and recaulked everything (to quote the dealer). We;ll see what happens next!
