Okay, the new drawer glide brackets are in and everything is back to the original operation. Now I'd like to improve it. For some reason to open the bottom drawer, between the microwave and sink, of the 235S (much like the 225 back end), I have always had to lift the bottom right corner a bit then lift the handle like normal to open it. Does this mean the left rear bracket attachment is too high or the right front bracket should be raised?
BTW, I lined the area behind the drawer slide bracket with 1x2 and screwed it to the backwall. Anticipating the bouncing our homes get I mounted the wood so its bottom would ride with the floor and positioned it vertically. With the wood the bracket engages the slide an inch more than before. It was hanging precariuosly on the front 1/2 inch of the bracket before. According to my measurements a new 24 inch drawer glide wouldn't fit and the 22 inch drawer glides wouldn't fully enter the bracket. I was able to secure two screws for each bracket into the wood.
