>TonyTiger - What all did you replace? Just the plastic clip in the >rear that looks a little like a lazy "C"? The 1x2 (resting on the >floor) behind the clip certainly sounds like a good idea.
I had to replace the bracket, looks more like a 'T'. The broken one split right where the foot attaches to the upright
_
/ Kind of like that.
The new ones look more like an "L" with a thick foot to accomodate the drawer slide guide.
I ordered new brackets, mounted the 1x2 to the back wall, then mounted the brackets to the 1x2. The drawer slide guides themselves slide into the bracket. I tried to use a level but I could be off a bit.
Still haven't figured out the hard opening. You really need to lift the bottom right front of the cabinet about 1/8" to then lift up on the handle to open normally. Even though mine is off set from the microwave (they put a swinging door on the compartment under the microwave on mine) I'm sure it is the same drawer hardware.
