Hello Plusit,
You mentioned that you installed a telescoping battery tray. I have been tinkering with that idea too. You mentioned that it was still not as convenient as you had hoped it to be.
I’m not sure how your works but if it is on the same set-up that I am thinking of putting in here is a suggestion. If you water level is hard to check because of the small access flip
door that we currently have to check our batteries ,than you might want to consider this. The panel ( fiberglass skirt ) below the floor line has no structural value and is used just to cover the area. I am going to cut out about a foot and a half of the panel install a few hinges so that the cut –out piece will flip up on the hinges to have clear access to the batteries .
I just got back from a week in Lancaster PA with the B+. When I get back to feeling 100% I will start on a few more projects. I had been thinking of replacing my wheel Hub caps with a nice set of Stainless Steel wheel liners but could not justify the cost, well I can now I lost one on the road , my wife still thinks I did it on purpose!
