I just bought a Trail Lite B+ 211s with 8.1 Chevy engine. This is my fifth motorhome (others range from an old 20' Vagabond, and three Winnegagos, from 19 to 32'. This vehicle is fantastic. I am...
cheeze I have a 2003 Trail-Lite 225 B+. The water tank is under the couch,but I cannot find the valves to drain the water tank? Above the couch on the left end is a sticker that says low point drain.Ilooked under the rv behind rear wheels on drivers side & found 2 pipes,but are not pluged. On the lines at the water tank there is a little black object with a ring at the top.Don't know what that is,also the same thing in the lines from the faucets in bathroom. Thanks for your response. Valoy
