we have the 2005 213 b+ and would also like to get to scoop on draining hot and cold stored freshwater, not for winter, but to ensure that water really is fresh each trip. how long does it stay fresh before you gotta worry. for now, we run the tsnks empty from kitchen sink thru a hose out the door after trips.
thanks for location of freshwater tank info on earlier posts - opened dinette seat and found disconnected wire - now our freshwater mmonitor (and all monitors on panel in bath) works fine. there is a red spot between the electric and gas switches that must be selected in association with turning on hot water switch. is it a light? if so, when is it to come on (the red light comes on the hot water swithc on the monitor panel).
we got the oven pilot lit. we found that the city water was only leaking at the hose hookup gasket, so no biggie.
Thus, the only T/L defect we know of is the trivial unconnected roof speaker - they were wired to serving as a rear set for dash radio, so we fade to cockpit door speakers only. wish the speakers were wired to TV, but am not about to take all that stuff out (we have the 24" RCA set and a separate RCA DVD.
thanks
