cheese1 - Thankfully, I corrected all of the rattles in our unit. None were significant, just annoying. The leg on the table was adjustable and the adjuster was loose - removed it and replaced with a bolt. The cover over the stove burners would rattle, bought different stick on rubber bumpers. The twist adjustment for the blinds would bang against the window if fully raised, now we don't raise the blinds clear to the top. Fabric covered wooden valance around the window was loose, tightened the screws. Steel roller under the sliding couch rattled, bought tapered rubber doorstop and let roller rest on that. Most were found when I was able to be a passenger. Rides so quiet now, it is almost spooky.
