It took all morning, but I was finally able to upload a rig pic that can be seen in 'view profile' (finally realized the web acceletrator had to be turned off). The pic includes our small bass boat on the only trip we've pulled it so far about a year ago.
I intend to pull the dually hubcap and check and add air. last time filled was last august when alignment shop put 65 in all tires. I am fine with 50 psi, and have checked the front and outer rear wheels a time or two since august. If I can fill to 65 and have it last 10 months before hitting below 50 psi, I do not mind pulling the hubcaps off once a year or so...
But the convenience and look of the two-piece set is interesting me.
Any opinions as to which set of hubcaps (existing or the 2 piece ring + small hub cover' would look better?
