I just bought a Trail Lite B+ 211s with 8.1 Chevy engine. This is my fifth motorhome (others range from an old 20' Vagabond, and three Winnegagos, from 19 to 32'. This vehicle is fantastic. I am...
cheeze1 - We never have had a problem with water in the rear compartment. burlmart - You got the description of a bottle jack correct, but if it really is only a 3 ton you might have to really work it to lift the rear. Your rear axle weighs about 3 ton so that jack will almost lift all of that until that side clears the ground. Ph - I hope your scenario of summer sun and underinflation were the factors for tire failure. Would hate to think I should replace 6 tires that still look new.
