We own a 06 251 and now have just under 12,000 miles on ours. It is just about the perfect size for two people, especially if you plan not to pull a Toad. I set up a toad for mine and used it to bring the motorhome 200 miles home from the dealer last January. Haven't felt the need of it since. Ours has been West thru the Mojave desert up the coast to the Golden gate bridge, across the US to the UP of Michigan and as far South as Tampa Bay in Fl. The Chevy chassis runs superbly and the unit is probably the most trouble-free of all the Moho's I have owned in the last 16 years. Asking price is a little High, but rule of thumb says anything with warranty left from the chassis manufacturer is always worth a bit more. If you dont need the dinette, I suggest replacing it with a Flexsteel Magic-bed, if you need more than one main bed. I attach a fitted ful-size sheet to the mattress with safety pins and use a down comforter as at blanket over a top sheet. The bed makes easily then and you only need to pull off the bottom sheet when you feel the need to wash it. Go for it if it is the new 6.0 chev, should get around 11 MPG at 70 MPH.
