Hi Gang, after camping in warm weather for the first time, I realized that I need to re-install my awning. However I want to do a better job than Rvision. My main beef is the way the lower arm brackets were installed. They were just bolted thru the coach wall with lag bolts, and 2 of the 4 were loose. I would like to use a machine bolt and nut+backing plate to make it secure. However, since the RV is 25 min away, I was wondering if any of the bretheren and sisteren out there with a 213 or 225 could check their lower awning brackets and see if there is clearance on the inside of the wall where I could get a backing plate and nut. I want to buy stainless steel bolts so I can do the job right.
Thanks!!
