CONGRATULATIONS. That is how they all should be, and now with some TLC from proud new owners, many more pleasant trips are in the future. Now you have got her home, clean her up and do the regular maintenance things. Washing the rig can be done with any good carwash liquid, I like and regularly use Turtlewax carwash compound which I buy in 1/2 gallon jugs from Wally World. It does a good job and does leave a wax film if you don't have the energy to wax.Check her all over again and look for things that may have changed, such as NEW loose components and fittings, Go around and tighten anything which has come loose and check your batteries and other systems for leaks or changes. If everything looks OK, prop the fridge open and find a good storage checklist, although, I would sure think about taking her out a few more times, even if it is only to a handy statepark near home for the weekend. That helps you to keep familiar with the systems and you will soon learn how to put things up ready to hop in for a quick trip.
