It's done, thank goodness.....did it the Gene way, no T-connector, just pried off the hose to water tank and let the pump pump away....1.5 gallons, all the traps too. Did use air compressor from our son (grandpa's gift) at 40 psi first as our 110 compressor hose had a hole!!!! DH said not enough space to work and place the winterizing kit....CharlesOK probably knows as the pump is between the back wall and tank, after having to take linen off bed, mattress (tight fit, nasty words!!) off and then plywood (8 screws). Did find the low drain plugs just where CharlesOK said, so they've been open for the whole ordeal. Gotta go South next year, too much trouble to stay in Washington!!! Again Thank you ALL. :)
