burlmart -
Q1: Does anyone know what to call these swing hinges, and where to get them? I'm also at a loss. Someone on this forum should be able to answer that. I know my dinette table acts a little like that where you hook it in a raised position and then drop for making into a bed.
Q2: Anyone know the right treatment to stop this corrosion? Is it too late for baking soda alone? Here is what I would try, use the baking soda to dissolve the corrosion, rinse with water, and then lightly coat with grease to prevent the return.
Q3: If I am so lucky, what type of bulb do I need to get to replace this one - has anyone ever had to go up and replace one of these? I have been lucky and have not had to replace mine. My guess is that they would use the same type of bulb in all the clearance lights.
